Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Scan tool adapter for 1995 Camaro
Old Nov 1, 2007 | 12:54 PM
Default Scan tool adapter for 1995 Camaro
1995 Camaros use an OBDI computer, but the diagnostic connector is a 16 pin OBDII type. In order to attachthe OBDIscan tool an adapter is needed. These two jumper cables will work as an adaptor.
Use two jumper cablesconfigured as idicated. One end of each cable is attached to analligator clip, andthe otherend of each cable is attached to a male pin. For best results used soldered connections to make the cables up. Parts can be obtained from Radio Shack.Look for alligator clips with a rubber shield to prevent shorts.
To use the scanner attach the cables as shown on the diagram:
1) Attach the alligator clip end to the pin on the scanner cable -
2) Insert the pin end of the jumper cable into the female socket on your vehicle's 16 pin connector.
jtrotter
May 3, 2012 10:37 PM
jamesfs912
Oct 23, 2009 06:22 AM
draggo144
82-92 V8 Tech
Mar 27, 2009 04:33 PM
Brians 88 IROC
82-92 V8 Tech
Aug 31, 2008 08:58 AM
twistedpyro
Mar 15, 2008 12:34 AM
