diagnostic diagnosis
#52
i have a test tomorrow @ 8 in the morning. it will run till around noon or so.. after that i got to go to olympia and get my bow tuned up with a new peep sight. hunting season is just around the corner....
#54
Sorry gave you wrong info, was looking at V6 DTCs, so I deletet the posts. DTC 16 could be due to a bad Opti, or a wiring/ connector problem between Opti and PCM. Check Red/Blk wire from pin A on opti to pin B2 on PCM (Black Connector). Most likely a bad Opti, but should check out the wiring, just in case.
#56
Possible being that the PCM gets power from the ignition switch over fuse #5 (Inst Pan box), and then the PCM provides power for the opti (Red wire on Opti). Ign sw also provides power to the coil over fuse #11 (Under Hood box)
