Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Carb- 350ci '71
Old 11-19-2009, 11:12 PM
Y2K's Avatar
Y2K
Y2K is offline
Originally Posted by CamaroGuy71
I dont recall what's on the engine. I believe its just the stock ignition.
Well if it's stock '71 stuff it's points fired,most replaced motors wind up with a later style stock HEI on them but who knows after all these years.
It's easy to tell,the points ignition has a coil wire and separate coil,the HEI has the coil built in the dizzy cap so no coil wire.
  #22
Old 11-19-2009, 11:34 PM
CamaroGuy71's Avatar
Originally Posted by Y2K
You'd have to call Summit's tech line on that one,I'm not sure what they mean by that but I'd assume maybe a more performance oriented advance curve etc. for a performance cammed engine.
makes sense to me.
  #23
Old 12-18-2009, 03:06 PM
oxigide09's Avatar
Default Carb 350ci 71
I would put smaller jets in both carbs... If it ran perfectally with each carb individually then its probably rich with both. Ive never messed with dual carbs but that would be my thinking. Now each one only has to provide half the gas to maintain the perfect Air/Fuel Ratio.
Tat01
03-25-2015 05:55 PM
albo1989
82-92 V8 Tech
07-01-2010 07:40 PM
rockin85
09-28-2007 08:47 AM
purpl96
08-09-2007 08:38 AM
350rs
12-22-2006 10:31 PM
Quick Reply: Carb- 350ci '71
