Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
1992 Camaro fuel pump
Old Oct 17, 2010 | 08:39 AM
RoyBean's Avatar
Default 1992 Camaro fuel pump
I just bought this "92" 305 RS and I am not hearing the fuel pump.
The car will run pouring gas down the intake.
Is there a fuse for the fuel pump circut? I'll check the relay in a little while. (after the weather warms up a bit)
The PO told me they had removed some fuses from the fuse panel.
I can't read the diagram in the manual. The writing is too small.
Thanks in advance. Roy
Old Oct 17, 2010 | 10:46 AM
RoyBean's Avatar
Does anyone know if the gray wire going to the fuel pump is the hot wire?
What is the purple wire for on the fuel pump?
I am getting low voltage on the purple wire and none on the grey wire. Roy
Old Oct 17, 2010 | 11:12 AM
RoyBean's Avatar
I think I may have found the problem. Roy
Old Oct 17, 2010 | 12:50 PM
better clean your gas tank out. looks like some water got in there at one time.
Old Oct 17, 2010 | 01:43 PM
RoyBean's Avatar
I also think some gasahol got in there too.
The car fired right up. I then drove it off the trailer and drove it down the road. Runs fine and shifts fine.
This is the first time the car has run in a long time. Roy
Old Oct 17, 2010 | 02:29 PM
How'd you get it apart, back together, and running so fast. Did you drop the tank to get to the pump? That crumbly/split rubber connector looks a lot like the one my 91 had, same problem.
Old Oct 17, 2010 | 04:18 PM
RoyBean's Avatar
Some one cut the fuel pump out before. I was chasing down the fuel pump wires down and saw where they butchered the metal.
Something else to fix. Roy
Jacob Bailey
82-92 V6 Tech
Aug 14, 2012 05:46 PM
aznjim68camaro
Feb 11, 2011 02:15 PM
samtron
Oct 1, 2009 11:32 AM
chevyman81
Dec 19, 2006 05:48 PM
92CAMARO
Jan 26, 2006 02:07 PM
