92 CAMARO FUEL PUMP FUSE!!! HELP!
Old Jan 20, 2006 | 09:14 PM
92CAMARO's Avatar
Default 92 CAMARO FUEL PUMP FUSE!!! HELP!
where is the fuel pump fuse on a 92 camaro. thxs.
Old Jan 20, 2006 | 09:18 PM
92CAMARO's Avatar
Default RE: 92 CAMARO RS FUEL PUMP FUSE!!! HELP!
MY CAMARO COMES WITH AN ELECTRIC FUEL PUMP IN THE TANK.
Old Jan 22, 2006 | 12:54 AM
Dancj2's Avatar
not sure about the fuse, but i heard to get that fuel pump out you have to drop the rear end!
Dannie
Old Jan 22, 2006 | 08:00 PM
Sleeper91's Avatar
Default RE: 92 CAMARO FUEL PUMP FUSE!!! HELP!
There isn't. If it's TBI then you have individual fuses under the dash for the injectors, and thats where all the fuses are.
If you look under the car right before the tank there is a connector for the fuel pump, test for power there, and if you do have to do the fuel pump you gotta drop out the rear end. I did it last year it's a *****
Old Jan 24, 2006 | 04:47 AM
Dancj2's Avatar
My buddy has to do it, so i check those fuses, I hope its that. I dont want to drop the rear end![:@]
Dannie
Old Jan 24, 2006 | 09:33 PM
jaydubb's Avatar
Check behind the battery. You will see something bolted to the fender with 2 wires coming out of it. UNCLIP that assembly and you will find the fuse.
Old Jan 25, 2006 | 12:15 AM
v8chvyguy's Avatar
get a repair manual it will have the wireing diagrams in it as well as test procedures to trouble shoot the system. On TBI and diesel trucks the fuse is found next to the relay on the firewall pass side. I'm guessing that your car wont start or the fuel pump is INOP. the fuel sys. electrical wireing is fun to trouble shoot, I had to do it on a 93 C3500. If the systems are the same there are a few reasons why the relay wont signal the pump to start.
Old Jan 25, 2006 | 07:09 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
I copied the testing procedure from my chiltons book. it is pinned in this forum.
Old Jan 26, 2006 | 03:06 AM
Dancj2's Avatar
ORIGINAL: nj85z28
Ur just on top of things!!
Old Jan 26, 2006 | 02:07 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
what is wrong with the pump btw? is it running all the time or not at all?
aznjim68camaro
Feb 11, 2011 02:15 PM
jwarren219
Oct 2, 2009 08:49 AM
samtron
Oct 1, 2009 11:32 AM
er1c
Jun 3, 2009 01:20 PM
mgray
Jun 12, 2007 05:35 AM
