Camaro Reference, Repair and Owners Manuals Here we have reference information, repair manuals, owners manuals and other information you might find interesting
If anyone needs repair/diag info
Old Jan 14, 2017 | 08:33 PM
  #31
download the shop manual for your year (whatever it is) here, https://www.mediafire.com/?40mfgeoe4ctti
Old Jul 9, 2019 | 05:50 PM
  #32
turtleman99's Avatar
Looking for engine digram of 2014 Camaro Rs 3.6L V6. Mainly need location of Knock Sensors
Old Sep 19, 2021 | 08:23 PM
  #33
Speed man's Avatar
Default Firing order
Originally Posted by mach2mack
I am a professional technician and have access to the factory GM site I can get things like wireing diagrams, diagnostic flow charts all that stuff. Just thought it might be able to help some people
I have a 2015 camaro v6 3.6 I need to know the firing order on it I am getting a code reading of PO305 but I am finding two different firing order on them . Does anyone know for sure
Old Aug 14, 2022 | 12:27 PM
  #34
dougq's Avatar
Default Wanted engine manual or info re: 1981 229 cid v6.
I cannot locate the casting # or ID info to confirm the engine source.
A vacuum diagram, wiring diagram etc would be most helpful.
Any help appreciated.
Thanks
DougQ
Old Sep 19, 2022 | 07:29 PM
  #35
Franny's Avatar
Default I need help
I have a 95 Chevy z28 LT1 f body v8. It won't stay running after it warms up. I've changed the fuel filter the plugs the coil the starter the module the temp sensor had alternator tested it passed 5 times checked the opti it has spark she is running rich to where the exhaust burns my eyes. N backfires but it sounds like it is backfiring in the front. I wanted to check my o2 sensors but I have no idea where they are located n when I go to look it up I get info for the 94 v6 I can't run codes I've tried it always tells me error cannot link at this time??
Old Sep 19, 2022 | 07:30 PM
  #36
Franny's Avatar
Default I need help
Old Sep 19, 2022 | 09:41 PM
  #37
he has not been on site for 10 years, odds of getting response are slim. sounds like you really need to get a good scanner on it to see what's going on. look at 24 here 4th Gen LT1 F-Body Tech Aids lots of good info on shbox.
Old Sep 27, 2022 | 05:13 PM
  #38
PapaJo's Avatar
Default 94 Z28 suspension and brakes interchange years
Hello , I'm looking for interchange info for my 94 Z28. Mainly suspension and brake parts. So far all I've found is 93-97 or 98-02 . Just making sure because i found parts from a 2000 SS but wanna make sure stuff swaps to a 94 before i buy. Thanks.
Old Sep 27, 2022 | 11:12 PM
  #39
I pretty much stay away from 97-02, many 97 parts are good for some of the other 93-96 years and many are not. most parts on the 98-02 won't work on the 93-96. many parts for my 93 are for my year only, 94 is also a one off year for some parts. computer and auto trans come to mind. for some parts try looking at rock auto and see if part numbers are same.
CamBigCat
May 28, 2016 02:04 PM
Yooper Z28
Nov 26, 2011 12:10 AM
jrdnrdg
Jul 16, 2011 06:51 PM
98CamaroRS
Apr 16, 2010 09:30 PM
