will monsoon work?
Old Apr 21, 2008 | 10:38 AM
th3po1son's Avatar
Default RE: will monsoon work?
alright well ive got the stock bose stereo and if i wanted to take a monsoon head unit and some speakers from like a 2002 or something that i get on ebay can i just switch everything out? like all the speakers and subs and amps?
Old Apr 21, 2008 | 10:56 AM
SpecterGT260's Avatar
Ninja Administrator
ORIGINAL: bluovlh8er
you guys........ monsoon is like the bose from 93-96
nothing is interchangable and the speakers are all f-ed up ohms... with each individual amp [:@]
the ohms are a little goofy, but thats because of the monsoon amp that drives the monsoon system, not the head unit. in a monsoon system the tweeters are the only things driven right off the HU. and they are 4ohm standard.
if nothing is interchangable why was I able to plug my new pioneer HU straight in with no problems? still using factory amp.
monsoon --> Pioneer
base ----> pioneer
pioneer = constant
therefore
monsoon <----> base
just make sure the harnesses match up or do some splicing and you will be ready to rock. personally, unless ur getting the monsoon HU for free id go get a better aftermarket deck. the factory charges outrageous prices for monsoon parts. $80 for EACH paper woofer in my TA sail panels. I got a PAIR of SVC 6.5" woofers to go in there which works amazing and is about 7x the quality of stock for 70 bucks shipped.
Old Apr 21, 2008 | 10:58 AM
Ninja Administrator
some other systems like the mustang Mach1000 as well as their sub-high quality system (which is a ginormous pita....) have a lead wire coming from the HU to the amp. without the ford HU the amp wont turn on. this is a common problem with high end factory systems. fortunately chevy decided to make up partially for the crappy rear end with a user friendly stereo. the factory amp uses a remote wire similar to any other after market amp and will thus turn on with pretty much any head unit.
Old Nov 14, 2008 | 01:08 PM
jjbova's Avatar
So if the HU says Monsoon, you have the whole monsoon set up? I was wondering cause I have the 6 speakers, but they sound like crap. I too want to replace them just to have that little better sound quality (not really going for a whole "system"). And you are saying I have to be careful with the OLMS and all that. Does any one know what the ratings are for the stock speakers so I can match it with aftermarket?
Old Dec 9, 2008 | 11:51 AM
jjbova's Avatar
Never mind, I found the ratings for the speakers on here. The doors and sail panels are both 2 ohm and the back speakers are 4.
Old Dec 9, 2008 | 12:56 PM
02StanGT's Avatar
You can look by the spare tire, and there should be an amp mounted there. I just saw this the other day while looking around in the trunk.
Caz
Oct 29, 2012 02:16 AM
tacameron
Dec 22, 2011 08:29 AM
blackenedss
Oct 22, 2009 03:35 PM
Jsnives
Aug 10, 2008 10:00 AM
Ophee
Jul 28, 2007 06:18 PM
