whats the best part
Old Feb 21, 2009 | 02:03 PM
94z28chevy's Avatar
Default whats the best part
i am making my own sub box in my 85 camaro and was wondering what is the best type of wood to use. i made it out of cardboard first for templates http://www.fquick.com/garages/viewga...wimg&id=227649
http://www.fquick.com/garages/viewga...wimg&id=227650
Old Feb 22, 2009 | 11:19 AM
ABKorrupt's Avatar
for subs always use MDF fiberboard. you can get at lowes for pretty cheap. probably build hole box for 20$
Old Feb 22, 2009 | 01:22 PM
Freshcamaro's Avatar
How many and what size subs are u looking to put in there. along with the amp. and does ur car have t-tops.
Old Feb 22, 2009 | 03:52 PM
94z28chevy's Avatar
well i was planing on putting 15s in and yes my car has t tops amp size i am not 100% sure yet but leaning towerd two 1200 amps with campasters for them
Old Feb 22, 2009 | 11:23 PM
greenarrow's Avatar
September 2009 ROTM
I would suggest 3/4 inch MDF like above, use some caulk at the joints to be sure to make it airtight. Predrill your screw holes or you'll crack the wood putting them in. I would suggest two 10's or 12's. Your going to have a had time getting the airspace needed for two 15's unless you use part of the deck behind the seat. Two 10's or 12's will sound better and will give you more flexiblity on your box design and still getting the airspace you need. Either way you go, make a box divider so you have two sealed areas for your speakers, will make them sound much better. Don't make squares in your box, unless you have to. If you do have to make squares, then add reflector slats to throw off noise waves. A square will cause the noise waves to cancel each other out, adding stats inside at odd angles will cause the noise waves to bounch around different, and not cancel each other out. If you need more info, then PM me and I'll send you a diagram or what I'm talking about. I've built a few boxes for third and fourth gen, so I got some expierece, take a look at my setup in my pics if you'd like.
Tomg303
70-81 V8 Tech
Oct 15, 2012 05:34 PM
camaro1997cb
Jun 28, 2009 07:06 PM
nascarlatemod06
May 7, 2009 03:17 PM
shadowedls1
General Racing/Tech
71
Jul 27, 2008 10:29 PM
