Fog lights
Old Feb 22, 2009 | 08:41 AM
BPS's Avatar
BPS
Default Fog lights
I just bought a 1987 Iroc... the fog lights didnt work. There was no power at the switch I traced power back to relay on drivers side behind head lights. If i jump out the relay I then have power to the switch. Anybody know where the problem lies? and the solution
Old Feb 22, 2009 | 01:27 PM
Freshcamaro's Avatar
well if u have power to the switch when u jump the relay its more than likely the relay it self.
Old Feb 22, 2009 | 11:27 PM
greenarrow's Avatar
September 2009 ROTM
the switch is the power to the relay, when you flip the switch it sends power to the relay turning it on. By you jumping it, you're sending power backwards. You need to find out where the switch gets it's power and the fix should be there. It should get it's power from the fuse box, if the fuse is good for it, then you're problem is between the fuse box and the switch. Hope this helps.
pojo1988
Aug 27, 2017 09:35 PM
98Z28ImportSlayer
Mar 16, 2012 09:07 AM
Bing
Sep 20, 2010 08:09 AM
bodykits
Jul 1, 2009 09:52 PM
91 RS
Feb 24, 2007 11:14 PM
