Whats this part called
Old Oct 15, 2012 | 11:44 AM
Tomg303's Avatar
Default Whats this part called
Hey sorry for the dumb question. I was wondering what the right angle adapter coming out of the brake booster is called. The vacuum hose attaches to it. Mine is missing. Also should I run it to the back of my edelbrock carb or to the intake which is an edelbrock performer. Thanks
Old Oct 15, 2012 | 12:13 PM
Flextrainer's Avatar
Default Check valve
Should be a check valve. For vacuum or vapor. One is small banjo shaped (vacuum) one is bigger and round (vapor). Vapor is usually inline not in booster so yours sounds like a vacuum check valve. Should go to intake preferred. Usually run PCV to carb.
Old Oct 15, 2012 | 12:18 PM
Base of the carburetor is manifold vacuum, so you can hook it to whichever one is more convenient.
Look at the "Help" rack at Autozone, they may have that fitting.
Old Oct 15, 2012 | 05:13 PM
Tomg303's Avatar
What fitting should I use on the carb to attach the hose?
Old Oct 15, 2012 | 05:34 PM
A barb fitting. You can get it in the plumbing section at Home Dopey, or an auto store may have one too.
Not sure what the size is, use a ruler.
libertyforall1776
Apr 24, 2013 06:06 PM
camaro1997cb
Jun 28, 2009 07:06 PM
nascarlatemod06
May 7, 2009 03:17 PM
98sleeper
Jul 23, 2008 06:55 PM
V8Z
Aug 17, 2006 02:28 AM
