wanna hook up an amp
Old Feb 19, 2008 | 10:45 PM
blkgagt94's Avatar
Default wanna hook up an amp
ok i got the factory bose system 5 speakers an amp i wanna hook up an amp for a sub iam leaving the stock bose cd player in. i know how to hook everything up but since the speakers are ran to the factory amp iam gonna go buy the rca converter. other cars all u gota do is run it to the 2 rear speakes an you got signal but will it work with the speakers hooked to the fatory amp?
Old Feb 20, 2008 | 12:57 PM
ninetysixyenko's Avatar
Default RE: wanna hook up an amp
im not completely sure, but i dont beleave you have to bypass anything for a sub and sub amp.
Old Feb 20, 2008 | 03:05 PM
yourGrandma's Avatar
you might want to check out your rear speakers...(back seat) if they are like mine you might be in for a suprise!!!
Old Feb 20, 2008 | 04:50 PM
blkgagt94's Avatar
like i said bose factory set up an if i re did the head unit with a aftermarket one i wouldnt be askin since i know how to install it but all the other cars i did i used the rca special splitter on the rear speakers but never did it with the bose speakers an amp
Old Feb 21, 2008 | 05:41 PM
RCA splitter should work on the rear speakers
isaackrammes
Nov 26, 2014 06:26 AM
jeffchairs
Sep 7, 2014 02:25 PM
-Tommy-
Nov 25, 2009 04:06 PM
250motorsportz
Mar 31, 2008 12:57 AM
microkid
Jun 4, 2007 08:20 PM
