where can i hook this up?
Old Jun 2, 2007 | 02:55 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default where can i hook this up?
i need to find someplace to put in the oil pressure sending unit for my autometer gauges. i looked around the oil filter and such and didnt see any good places. its an electric sending unit.
Old Jun 2, 2007 | 03:16 PM
1985RS's Avatar
Default RE: where can i hook this up?
does the sender have threads on it? if so, look at taking one of the plugs out of your main oil rifle
Old Jun 2, 2007 | 08:01 PM
MadMikeZ28's Avatar
Is there no plug by the filter?
Old Jun 2, 2007 | 10:00 PM
Danzig's Avatar
Are you also going to be using the factory gauge in the dash?
Old Jun 2, 2007 | 11:48 PM
MadMikeZ28's Avatar
Yes he could just tap into that one. He does need to keep the oem sender because the fuel pump works through it. But I would want the sender that came with the gauge because I believe the Autometer sender is more accurate.
Old Jun 3, 2007 | 07:26 AM
350rs's Avatar
March 2008 ROTM
hey, when i did mine, i used a plug in the back of the manifold just below the distributor cap. I had to get a 90 degree elbow and a small extension for it to fit though. then again, your runninga TPI, it may not have anything like that. But thats where i went, have a look, maybe it has one still.
Old Jun 3, 2007 | 11:21 AM
microkid's Avatar
March 2011 ROTM
Technical User
yes, the sender is threaded. where is the oil rifle? i didnt see any plugs except for a freeze plug toward the middle. my factory gauge wiring is fried, which is why im using aftermarket gauges. and the guage will only work with the included sender, the oem wont. if there is a plug behind the distributor, i cant fit my hand down into there
my block is really dirty, i may have missed seeing a location to hook it up.
Old Jun 3, 2007 | 06:09 PM
MadMikeZ28's Avatar
There is a hole in the block near the dizzy. I think on the left side of it. That is where oil pressure senders hook to. Or yours may be already by the oil filter. Do you already have a long black thing coming out by the filter?
Old Jun 4, 2007 | 08:20 PM
microkid's Avatar
March 2011 ROTM
Technical User
hhmmm, long black thing. i dont remember, but once shes back together tomarrow ill put it on the ramps and look.
isaackrammes
Nov 26, 2014 06:26 AM
jeffchairs
Sep 7, 2014 02:25 PM
-Tommy-
Nov 25, 2009 04:06 PM
250motorsportz
Mar 31, 2008 12:57 AM
blkgagt94
Feb 21, 2008 05:41 PM
