Viper alarm system
Old Oct 2, 2008 | 10:21 AM
CMRO GRL's Avatar
May 2008 ROTM
Default Viper alarm system
I have heard there were many issues with the Viper Alarm Systems, and I am finall experiencing my own. Any help would be much appreciated...
So here is what is going on:
For the past month or so (maybe not quite as long), I have been experiencing problems with my alarm. Well, not the alarm, but locking and unlocking it. I used to be able to unlock/lock it from very very far away, and I slowly have been needing to be closer and closer to the car. Then it used to take me about 20 tries to lock it with the remote. Now it doesnt lock or unlock at all, and, obviously, the alarm doesnt work when its unlocked. I have also noticed that the passenger side will sometimes lock on its own.
I have checked the battery (durr), and i have looked around online for a way to reprogram it or something, but i am comming up short. I mean, I know I could flip the switch for the alarm and just lock/unlock it manually... but I would like to figure this out.
Any help is very welcome
Cliff notes:
Viper alarm system = not so good
car wont lock
help? plz?
Old Oct 2, 2008 | 06:16 PM
TheStig's Avatar
Default RE: Viper alarm system
I dunno if it would work with your model, but this is the best I could find.
"Step 1: Open your car door
Step 2: Put the key in the ignition and turn it to the "Run" position.
Step 3: Push & release the program button (the black button in your car - usually located under dash or driver's kick panel) once and then release.
Step 4: Push & hold the program button in (keep holding).
(Unit -should- chirp once)
Step 5: Press and release a button on your remote (this button will be your arm/disarm button)
Step 6: Release the program button.
Step 7: Press & Release the program button.
Step 8: Press & Hold the program button (do not release).
(unit should chirp twice)
Step 9: Press button2 (or the other button) on your remote.
Step 10: Release program button.
Step 11: Turn key off.
(Unit should emit a long chirp to confirm)"
Old Oct 3, 2008 | 07:49 PM
CMRO GRL's Avatar
May 2008 ROTM
Wow, Mike.
Thank you =) I'll have to give this a try! Thanks a lot
Old Oct 3, 2008 | 08:58 PM
CMRO GRL's Avatar
May 2008 ROTM
now i just gotta hunt down that black button.... no luck so far, Im gonna try taking some pannels off though, if i can find that, things should be on their way
Old Oct 4, 2008 | 10:29 PM
84z50HO's Avatar
The plug shouldn't be to far from the brain as along as the installer didnt unplug it.Have you found the brain yet?
Old Oct 5, 2008 | 04:45 PM
CMRO GRL's Avatar
May 2008 ROTM
I found what i needed, it was right infront of me the whole time, i just passed right by it.... But I found the black reprogram button. It took me probably 20 tries, with the alarm blaring... but i finally reprogramed it.
Its pretty sensative, but now it works =)
Thanks for your help!
Old Jan 10, 2009 | 12:40 AM
M.$tErNeR's Avatar
yeah there tricky which is why i had it installed close by so wenever i have a problem they fix it for free under the warranty asap.did the black button let u lock from furthur distances.mine is the up to 1 mile and i get decent distance but it sure as hell aint even close to one mile.
scotty2756
Jun 12, 2010 07:32 PM
Nessy
Dec 2, 2008 10:59 PM
250motorsportz
Jul 3, 2008 01:29 AM
CMRO GRL
May 9, 2008 12:13 PM
