are these good
Old Mar 27, 2007 | 01:15 AM
  #21
vanilla sky's Avatar
Default RE: are these good
I'm building the front from scratch, too. I just have a lot more limitations in the front. I can't use enclosures in the front, I can only go with a 2 way system up front, and nothing off the shelf fits both my needs and my budget.
Old Mar 27, 2007 | 01:16 AM
  #22
Hisss04Cobra's Avatar
Why not?
Go buy a polk audio comp set, and buy a cheap zapco amp and you're set if you don't have much money.
Old Mar 27, 2007 | 01:22 AM
  #23
Because by building my own sets, I have control over everything that goes into my car. From the tweeters and the midbasses, to the caps, inductors, and L-pads that go into the crossovers. I can fine tune my setup. With an off the shelf solution, I'm stuck with what they give me, which may not be right for my car. Good active crossovers and EQs are expensive. Staying passive and using only simple active units keep costs down and still give me the potential to have a competent sound system.
Old Mar 27, 2007 | 01:26 AM
  #24
Then more power to you captain.
Stay away from those rear drivers though [sm=smiley20.gif]
Old Mar 27, 2007 | 01:32 AM
  #25
Duly noted
Old Mar 27, 2007 | 01:37 AM
  #26
What does, "duly" mean?
Old Mar 27, 2007 | 01:41 AM
  #27
Seight311's Avatar
Heres a good place to find some stuff if you want to piece together your own front stage.
Acoustic-visons.com
Old Mar 27, 2007 | 01:42 PM
  #28
"Duly noted" means "correctly or appropriately recorded."
The Acoustic-visions.com link isn't working. I tried a couple variations and got nothing.
Old Mar 27, 2007 | 02:07 PM
  #29
Seight311's Avatar
http://www.acoustic-visions.com
And yes for the most part these are designed for home audio use. But it's a great place to all the separate pieces you want, crossovers, woofers, mids, full ranges, silk tweeter, all kinds of goodies.
Old Mar 27, 2007 | 03:28 PM
  #30
I find it interesteing that two of the 3 brands over there are Dayton Audio (Parts Express) and Adire.
And wow, a single missing "i" is what kept me from seeing that. I'm usually the one to catch that stuff. Thanks for fixing the link!
