Speedomoter/RPM trouble
Old Mar 29, 2009 | 08:46 PM
Clh6387's Avatar
Default Speedomoter/RPM trouble
Hey...I'm brand new to this forum, and brand knew to owning a camaro. The speedomoter isn't working at all on my car, and the rpm's are supposedly about 1000 rpm's higher than the car actually is running at. I was wondering what steps I should take to fix these issues.
Thanks alot for your help. I'm brand new to working on cars, so please bare with me if some of my questions are lame. Thanks for the help.
Chris
Old Mar 30, 2009 | 12:40 AM
PAzYearazzUP's Avatar
No they are not lame. Because I can't answer them. So, speedo says trans sensor or something on the transmission is off at the tail end of the final output shaft. So, that is signal 1 say. Next is the dash cluster. Next is the CAN Communication to run wireless as no cables to turn the tach or speedo but an electrical pulse.
Simple stuff first is see if the sensor is putting out. Then it's wire to back of dash pod. Then yank the cluster out is send it out for inspection.
It it is cable driven. Again, look at the tail or where a cable is used. See if it is sheered off or does not spin at the speedo side.
Old Mar 30, 2009 | 12:39 PM
greenarrow's Avatar
September 2009 ROTM
Would help if you told us the details of your car. year/trim/mods and anything else you think we might want to know.
Old Apr 14, 2009 | 11:31 AM
SA_Adams's Avatar
also do u have an amp or anything else hooked up?
Old Apr 16, 2009 | 09:15 AM
Clh6387's Avatar
hey sorry haven't been on it a bit. Yea the car has two amp's in the trunk for the sound system. It's a 1980 z28. I've been busy runnin around sorry haven't been on in a lil bit.
Old Apr 16, 2009 | 09:56 AM
greenarrow's Avatar
September 2009 ROTM
For the speedo, check at the tranny and the gauges, should be cable driven so it's either broke or disconnected.
Old Apr 18, 2009 | 02:00 AM
Clh6387's Avatar
thanks for the advice...will do tomorrow. Also, my fuel gauge. It would usually take a little bit for it to settle in at the proper level. But I think as of recently now it just stays saying its full. I'm going to mess around and try to figure it out, but figured I'd throw this into the mix of questions as well. Thanks for bearing with me guys....I'm a newb hah
Old Apr 18, 2009 | 01:16 PM
ZAngler's Avatar
Does your gas gauge move at all? These chevy gas gauges are not that accurate or steedy! Mine moves all over the place!
Old Apr 21, 2009 | 12:25 PM
Clh6387's Avatar
you know what...it does move...what it used to do was take like 10 minutes to settle in ya know...and move around a bit but i had a good idea of where i was at. But lately its been stayin on full. I know the tank isn't full so I'm going to go fill it up this week....then see how she reacts while driving again. I just saw these sweet engines...the Year One Motors. I need like 5 grand to drop haha. I wana beast this thing out.
Dave81Z
Oct 8, 2009 11:15 AM
Chevy101
Feb 11, 2009 02:21 PM
hotdog453
Jun 21, 2008 04:25 PM
94firstcarAcamaro
Feb 11, 2008 09:58 PM
Solano
Dec 24, 2007 01:12 PM
