HID trouble
Old Feb 10, 2009 | 10:12 AM
Chevy101's Avatar
Default HID trouble
I bought a HID kit form intensehid.com for my 98 3.8L camaro and when i tried to install it nothing happened. in the directions it said if the headlights work off of one circut the fuse has to be a 30 and if it works off of two it has to be 20 each. anyone know the camaro uses one circut
Old Feb 10, 2009 | 11:38 AM
02StanGT's Avatar
There is a plug that you install on the ballast. If it is backwards, then the light will not turn on. I would try and turn them around, and see if the lights come on then. I have HIDs, and on none of my vehicles have I had to mess with fuses. They draw less power than regular bulbs, so I don't see why you would have to.
Old Feb 11, 2009 | 01:58 PM
Chevy101's Avatar
everything seems to hook up one way any other suggestions on why its not lighting?
Old Feb 11, 2009 | 02:21 PM
02StanGT's Avatar
Every kit I have had came with three pieces per headlight. A plug that goes from the stock socket to the ballast, the ballast, and the bulb. The piece from the stock plug to the ballast has always been "pill" (flat on the sides, rounded at the ends) shaped on the ballast end. It could be plugged it backwards. I agree that the rest is easy to figure out. If I get time after work, I will take a pic of what I am talking about.
jeanann73
Feb 2, 2013 09:05 PM
tncatfish
Apr 3, 2011 06:02 AM
smallzz28
Dec 8, 2009 04:17 PM
94firstcarAcamaro
Feb 11, 2008 09:58 PM
99 Camaro V6
Jan 6, 2007 02:55 PM
