power wire
Old Sep 15, 2006 | 02:02 PM
deang423's Avatar
Default power wire
Where is the best place to run a power wire through the firewall on a 96 z. I'd like to find a place on the passenger side since the battery is on that side.
Old Sep 15, 2006 | 05:03 PM
chadimus06's Avatar
Default RE: power wire
Im not to sure where a good place is on the passenger side but i drilled on the driver side right above the clutch pedal.
Old Sep 15, 2006 | 08:58 PM
Blade's Avatar
June 2007 ROTM
pretty sure ur gonna have to drill a hole, just make sure u fill it in so no water can get through.
Old Oct 6, 2006 | 04:48 PM
airchevy02's Avatar
i have a 2002 and there is a rubber plug about 2 inches around on the passenger side of the car, its a tight fit to run stuff though there but i think its well worth it bc it would be even hard to drill your own hole and its gonna be a tight fit too...
Old Oct 13, 2006 | 03:11 PM
shnormo's Avatar
Make sure you use a grommet!
DrDuran
Jun 18, 2013 03:48 AM
9434V6
Aug 19, 2011 08:52 AM
stonecoldtrk
Jul 19, 2009 08:13 PM
twankieman91
Dec 19, 2007 06:46 AM
