power wire
Where is the best place to run a power wire through the firewall on a 96 z. I'd like to find a place on the passenger side since the battery is on that side.
RE: power wire
Im not to sure where a good place is on the passenger side but i drilled on the driver side right above the clutch pedal.
RE: power wire
pretty sure ur gonna have to drill a hole, just make sure u fill it in so no water can get through.
RE: power wire
i have a 2002 and there is a rubber plug about 2 inches around on the passenger side of the car, its a tight fit to run stuff though there but i think its well worth it bc it would be even hard to drill your own hole and its gonna be a tight fit too...
RE: power wire
Make sure you use a grommet!
