VSS wire and REVERSE wire?????
Old Dec 18, 2007 | 05:34 PM
twankieman91's Avatar
Default VSS wire and REVERSE wire?????
hey guys i need some help... i have a 91 camaro rs with the stock 305.. auto... and i have recently purchased a cd player with a navigation system built in... to the the install it says for me to slice into the vss wire for the correct speed and the reverse wire for direction i think... problem is i have no idea what or where either one of these are so please help
Old Dec 19, 2007 | 01:37 AM
MadMikeZ28's Avatar
Default RE: VSS wire and REVERSE wire?????
Well if you want to go to the sources the VSS (Vehicle Speed Sensor) is on the tailshaft of the tranny and there is a switch on shifter under the top of the console for the reverse you can tap into.
It might be easy for you to tap into the VSS at the tranny and then feed the wire up through the gromit for the shifter cable then both wires will be in that same spot for the VSS and reverse.
Check out autozone.com in the repair section for wire diagrams.
Old Dec 19, 2007 | 06:46 AM
hey man thanks alot for the help.... i have to go to work now but i am going to try it as soon as i get home
Melissa Flournoy
May 1, 2012 07:11 AM
NorthernCrew454
Aug 20, 2011 07:14 PM
9434V6
Aug 19, 2011 08:52 AM
RatCamaro
Jan 29, 2011 08:55 AM
hshawn31
Jan 13, 2008 02:45 AM
