94 Z28 Exterior Door Window Trim Repair???
Old Mar 24, 2013 | 12:53 PM
rockinjohnny's Avatar
Default 94 Z28 Exterior Door Window Trim Repair???
The trim at the base of the window on the exterior of the drivers side door is popping up and almost comming off. Can I repair this without having to disassemble the door? Can you point me to a tech article that addresses this issue? Thanks in advance.
Old Apr 13, 2013 | 06:54 AM
FBodyjunkie's Avatar
Try looking it up on you tube. You will find what you need to do their. Good luck.
Old Apr 13, 2013 | 11:03 AM
thats the outer window seal. probly goin to pieces. install new one. i show rhs 10132208 and lhs 10132209 but the numbers arent any good. go here and you can find the part number to look up. http://performanceworks1.com/PDF%20F...s%20Manual.pdf
redsoxsstink
Sep 21, 2010 01:18 PM
bns454
Mar 16, 2010 06:33 AM
nortonm
Mar 4, 2009 11:37 AM
David56
Nov 3, 2008 11:36 PM
kyleag89
Oct 6, 2008 09:35 PM
