94 Z28 Exterior Door Window Trim Repair???
The trim at the base of the window on the exterior of the drivers side door is popping up and almost comming off. Can I repair this without having to disassemble the door? Can you point me to a tech article that addresses this issue? Thanks in advance.
Try looking it up on you tube. You will find what you need to do their. Good luck.
thats the outer window seal. probly goin to pieces. install new one. i show rhs 10132208 and lhs 10132209 but the numbers arent any good. go here and you can find the part number to look up. http://performanceworks1.com/PDF%20F...s%20Manual.pdf
