wont start?
Old 12-15-2010, 08:58 PM
nickb123's Avatar
Wouldn't it be harder/easier to turn depending on what point in the stroke is at? I just dropped the battery off at auto zone so there testing it.
  #32
Old 12-15-2010, 09:05 PM
osduck5's Avatar
Yes but you still should be able to rotate it one complete revolution even with compression building in the cylinders.
  #33
Old 12-15-2010, 09:10 PM
^^^ agree i can turn mine over with a half inch rachet. slowly.
  #34
Old 12-15-2010, 10:05 PM
nickb123's Avatar
I got the battery back to find out it's good but a little dead. I hooked it up, the car turned over a little. I did that maybe 3 times then it started for like 2 seconds then died with a loud sqeak type noise, I tried again it started for1 second and made the same noise, now it won't start again. I don't think that's a good sign.
  #35
Old 12-15-2010, 11:03 PM
just for piece of mind take the alternator/power steering/ac belt off and try to turn it over. sure sounds like a bearing siezing up though.
  #36
Old 12-16-2010, 08:04 AM
osduck5's Avatar
^^^^^ agree with craby! Your done! That squaking noise is your engine grinding itself to death.
  #37
Old 12-16-2010, 02:49 PM
nickb123's Avatar
well, do i need a new engine?
  #38
Old 12-16-2010, 03:48 PM
osduck5's Avatar
More than likely! You have a couple options. Replace with a donor, a crate engine or rebuild but if you spun a bearing and messed up the crank, you are looking at a complete rebuild with alot of machine shop work.
If you still are not sure, get someone local to come over and give you another opinion.
  #39
Old 12-17-2010, 08:56 AM
nickb123's Avatar
Could a 3800 engine from a fwd car like a buick or grand prix fit in a camaro? How much harder would it be to install than a engine pulled from another camaro?
  #40
Old 12-17-2010, 08:57 AM
nickb123's Avatar
and while I'm doind a engine swap, is there any cheap ways to make more power?
Quick Reply: wont start?
