wont start?
#22
The enternals heat up, metal expands and the bearings can, for a lack of better term, weld themselves to the crank and slowly grind to a halt, never to rotate again but more than likely, a bearing can spin allowing the rod to make contact with the inside of the engine where tolerances are maybe fingernail thickness apart and after a couple good licks, something hangs. Try to rotate the engine counter clockwise just a little to see if it will move.
#23
^^^ agree if you didnt notice if there was oil pressure during the time when it was clicking then you may have lost oil pressure. that will fry a motor. some sieze all at once, some dont. my daughter ran hers for 20 or so miles without oil pressure before asking me what the clicking noise was. added oil and it ran fine till she parked it for a few months. got a different car, now its dead. she couldnt get it to turn over to move it a couple months ago.
#24
ok so i turned the motor counter clockwise then clockwise. but it was not easy at all. i used a about a 3 foot breaker bar. the engine didnt move that much but it did. could that been enough to free the motor so the starter can turn it? and for oil pressure, im pretty sure it didnt loose any, I didnt look at the gauges directly though. is their a warming light for it?
#25
If it took a 3 foot breaker bar to move it, you more than likely have enternal engine issues. I bought one that had a seized engine and I was able to get the engine to move almost one complete revolution with a breaker bar before something snagged inside. However, with a brand new battery, the starter would not even move the crank. It had a spun bearing and jacked up crank.
#27
One other thing! I am assuming he car will roll in neutral, nothing in the tranny locked up
#28
im gona say drain the oil and check for any sign of metal in the oil. pull the oil filter and cut it open, cut the paper filter off and pull out the pleats and look for metal particles or shavings.
#29
so today i put the starter back in. then i turned the key and it turned a little. i put the breaker bar on the crank and it was a lot easyer. then i put the battery on the charger and turned it on the highest setting and it all most started for a second. then i turned it agian and it didnt move. i dont know if its the battery or what. should i get it tested?
#30
