water in the turn signal assembly
Old Apr 26, 2008 | 03:58 PM
johnnythehmc666's Avatar
Default water in the turn signal assembly
Ok so i have aftermarket turn signal assemblys, i put both of them in and went through the car wash. The driver side is fine, while the passenger side fills with water and of course condensates. This is like second turn signal assembly i went through. Is it possible that they were built bad? maybe a crack? If anyone can reccomend a place that sells better ones let me know. Thanks.
Old Apr 26, 2008 | 06:33 PM
typeomang's Avatar
Default RE: water in the turn signal assembly
do these have any warrenty?? and Altenza is a great brang if you like that look....SFC
Old Apr 27, 2008 | 12:34 AM
can u show me a link?
Old Apr 27, 2008 | 01:49 AM
02StanGT's Avatar
Take it out, empty the water, let it air out, and put some sealant around the edges.
Old Apr 27, 2008 | 11:37 AM
Old trick. Drill a 1/16" hole through the very bottom of the lens. This will let the condensation drain out, while the hole is too small to let water water in, unless you go in water deep enough to reach the hole.
Old May 7, 2008 | 08:49 PM
shai one's Avatar
I have the APC ones in my camaro and ive had them for about 5 years or so and no condensation..Maybe try those or try another brand of clear lenses.
Old May 7, 2008 | 08:59 PM
bluovlh8er's Avatar
anytime that happens there has to be a leak somewhere. (or it wouldent happen)
i would make sure the bulb socket is all the way in. with a good seal. and put some clear silicone sealent around the edges.
Old Nov 10, 2010 | 05:06 PM
rjohnson67's Avatar
I had this same problem, I sealed the edges with silicone.
JZ28
Mar 31, 2012 09:13 PM
Dj Aztek
Apr 8, 2010 10:27 PM
johnnythehmc666
Jan 31, 2008 08:17 PM
TakeTtopsOff
10
Nov 11, 2007 05:43 PM
84berlinetta
May 10, 2007 01:04 AM
