changing the turn signal assembly
Old Jan 31, 2008 | 01:20 AM
johnnythehmc666's Avatar
Default changing the turn signal assembly
what is the best method of changing out the whole turn signal assembly? on a 1999 camaro.
Old Jan 31, 2008 | 06:27 AM
02StanGT's Avatar
Default RE: changing the turn signal assembly
I've heard that on the '98+, you can remove it from the top, by removing the headlight to access it. This saves the pain of having to get it from below the car. It's two or three bolt/nuts that hold it on.
Old Jan 31, 2008 | 03:13 PM
hmmm, ill give it a try, are the bolts on that metal bar that hold the headlight?
Old Jan 31, 2008 | 03:27 PM
94 White Devil's Avatar
Im not 100% sure but on my 94 its bolted into the front bumper cover. 3-4 bolts hold it on.
Old Jan 31, 2008 | 05:45 PM
02StanGT's Avatar
They're all bolted to the inside of the bumper cover. I was just telling him it would be easier for him to go through the top instead of the bottom, since his is a '99. Johnny, I'm not sure how the headlights are held in on the '98+.,
Old Jan 31, 2008 | 08:16 PM
bluovlh8er's Avatar
ah even on the 98 + its easier from the bottom...
Old Jan 31, 2008 | 08:17 PM
so any way works then? o and a quick question how bad would it be to lower a camaro 1.4 inchs?
DashingDaryl
May 21, 2012 07:11 PM
pcarollo
Apr 27, 2011 09:26 AM
johnnythehmc666
Nov 10, 2010 05:06 PM
BoondockSaint862
Jun 18, 2007 11:16 AM
84berlinetta
May 10, 2007 01:04 AM
