fuel filter?
Old Jan 31, 2008 | 04:46 PM
LittleRedRocket's Avatar
Default fuel filter?
hey there i have a 95 camaro with 115,00 miles on it. i was wondering if i should go ahead and change my fuel filter because i am changing my spark plugs. please let me know know what you think.
Old Jan 31, 2008 | 08:17 PM
bluovlh8er's Avatar
Default RE: fuel filter?
when was the last time it was changed???????
Old Jan 31, 2008 | 10:38 PM
i know if it has ever been changed. is it hard to change?
Old Jan 31, 2008 | 10:51 PM
The Banks's Avatar
You're suppose to change it every 30,000 miles, but I don't see the need to unless you put in cheap gas and water or other debris gets in there. At 115,000 miles it can't hurt to change it, only an $8 or so filter.
What you have to do is:
1.relieve fuel pressure
2.jack it up
3.depress the white plastic quick-disconnect tab and detatch the lines from the filter
4.wrap a rag around the fuel lines so gas doesn't go everywhere
5.use a wrench to steady the filter and unscrew the fuel line and take off the filter (use a flare nut wrench on the fuel line if you can)
6.When putting on the new filter use needle nose pliars to push the tabs on the bracket into the chasis
You also might want to replace the O-ring on the end of the fuel line or just put a dab of oil on it when putting everything back together.
jon_uscg2001
Aug 25, 2011 12:23 AM
TrammelZ28
Sep 17, 2007 06:44 PM
johnson3034
May 25, 2007 09:35 PM
jtvyper456
Dec 31, 2006 09:33 PM
94camaroLI
May 16, 2006 09:57 PM
