water leak and shaking HELP.......
Old Aug 3, 2006 | 06:45 AM
Nightshift's Avatar
Default RE: water leak and shaking HELP.......
White residue on the plugs also means you're running too lean i thought? Also if he does have a blow head gasket, the coolant would turn a different color.
Be sure to check the PLUG WIRES and the COILS! When I get my car, it would miss and run like crap. Changed the plugs, fuel filter, cleaned the EGR vavle.. and nothing worked. I didn't want to look at the plug cables because I didn't have money to replace them. Well finally I brought myself to doing it and here I believe the number 5 cylinder's plug wire was RUSTED onto the top of the coil. I replaced the wires and cleaned the coil and now it runs just fine.
Old Aug 5, 2006 | 02:47 PM
superROB23's Avatar
well checked the egr valve and still nothing, my dad thinks its either the valves in the cam or the lifters. hope its just the valve.
Old Aug 5, 2006 | 02:49 PM
superROB23's Avatar
well checked the egr valve and still nothing, my dad thinks its either the valves in the cam or the lifters. hope its just the valve. where r the plug wires and the coils. i mean i change the sparks plugs and the wires a while back so those are new. i havent change the fuel filter yet but soon i will
Old Aug 5, 2006 | 07:39 PM
Nightshift's Avatar
The coil pack is what you hook the plug wires up to..
Old Aug 16, 2006 | 03:11 AM
superROB23's Avatar
ok i replaced the freeze plugs so im assuming there will be not more coolent leak, now a mechanic said that the shaking is from the exhaust pipes hiting against metal at least thats what they told me. the noise from the cam is because i need to change the oil to 20 50, ive been using 40 straight for the passed year.
Old Aug 16, 2006 | 03:13 AM
superROB23's Avatar
o im sorry i was wrong, i meant the back transmission mounts r proborlay going bad and need to be adjusted or replaced or something like that
Old Aug 19, 2006 | 05:51 PM
superROB23's Avatar
damn it after all that work and theres still coolent leaking. again i doubt its the gasket seals beacuse it doesnt have the symptom like smoking in the back exhaust and no backfire. i think there maybe a crack inside the engine block now damn, can anybody tell me what to do now. should i go check it in where they test engine blocks, or even the stupid gasket seals PLEASE HELP!!!!!!!!!!!!
Old Aug 19, 2006 | 06:43 PM
Do a compression test, it may show a bad cylinder. if that is the case the engine will have to come apart.
allen707
Sep 29, 2011 02:07 PM
Vetteman61
Feb 4, 2011 12:09 PM
Massey
Nov 4, 2010 10:44 PM
94camaro3.4
Jan 19, 2008 04:07 PM
94camaro3.4
Jan 19, 2008 03:48 PM
