Water leak
Old Feb 4, 2011 | 01:15 AM
Vetteman61's Avatar
Default Water leak
My 67 has to sit outside. I leaks water that puddles up in the front floorboards. It seems to almost drip down onto them in some places. Are there typical areas that are common to these models I should check first? Maybe a windshield reseal would be necessary.
I was hoping to maybe just recaulk and area and fix the problem, but I'm guessing it's not that easy.
Brandon
Old Feb 4, 2011 | 08:21 AM
Old cars like to leak, it's probably coming in from the cowl vent area.
For many reasons, more than just that leak, you should put a waterproof car cover on it.
Other damage that the weather can do to the car could end up costing you a lot more than a cover will.
Old Feb 4, 2011 | 09:09 AM
Vetteman61's Avatar
Is there a specific area or way to fix the cowl leak area?
Brandon
Old Feb 4, 2011 | 11:56 AM
carguy68ssrs's Avatar
You need to first climb inside car and try and see where water is coming from
Old Feb 4, 2011 | 12:09 PM
.....with someone outside working a garden hose to direct water in specific areas.
94z28red
Mar 20, 2011 08:49 PM
95z28htch
Mar 6, 2010 08:05 AM
AmirGTR
Mar 1, 2010 05:06 AM
94camaro3.4
Jan 19, 2008 04:07 PM
94camaro3.4
Jan 19, 2008 03:48 PM
