V6 Camaro Tires Rubbing
Old 06-29-2010, 12:05 AM
libertyforall1776's Avatar
Not exactly what you're asking, but for one thing, you need these in addition to your bump stops for 17" and bigger wheels:
http://www.hawksthirdgenparts.com/ca...erspacers.aspx
or these poly all-in-one units:
http://www.hawksthirdgenparts.com/ca...opnewgm-1.aspx
Old 06-29-2010, 12:49 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
i have 18x9 (i think) corvette c5 wheels on the rear of my car, and they rub when taking corners fast. I know it rubs on a little bump inside the fender well. I plan to fix by introducing the fender well to mr. sledge hammer
Old 06-29-2010, 11:01 AM
You need what I posted, at the least.
Old 06-29-2010, 12:34 PM
the_donace's Avatar
Damn do I really need those? You don't think the 1 inch spacer will fix it completely? I also plan on lowering it, would that give me any new problems with my wheel size? (I'm lowering it like 1.4in in the back) You need those bump stops only for the rear right?
Old 06-29-2010, 02:05 PM
Definitely need them, rear only. Keep in mind those are for 17", so with 18", you may still have a little issue, but less with the spacer.
Old 06-29-2010, 10:09 PM
the_donace's Avatar
Hmm damn, well I'll see how it goes with the spacers but I will probably buy these then. What exactly do they prevent from doing? My tires don't seem to rub in the area where those bump stops belong.
Old 06-30-2010, 01:33 AM
WOW are you lazy! Do you want me to translate the English from the web-page and spoon feed you too?
"They are designed to raise the jounce bumper stop to prevent tire contact with the inner wheel well."
Old 06-30-2010, 07:13 AM
evilkal's Avatar
You don't need poly bump stops. BFH that **** and be done with it. That's what I did.
Old 06-30-2010, 01:43 PM
I didn't say he needed poly, but he needs the jounce spacers.
There is also a poly version that already has it integrated.
markinnaples
10
06-07-2015 09:06 PM
aappss01
04-17-2012 10:11 AM
minex
10-02-2010 06:59 PM
Mr.Hudnall
09-17-2009 04:24 PM
Quick Reply: V6 Camaro Tires Rubbing
