Transmission or Clutch or something else?
Old Jul 25, 2009 | 12:16 PM
pedwards3x's Avatar
Default Transmission or Clutch or something else?
'94 3.4 5 spd manual...in third and sometimes fourth gear my car has been stuttering for lack of a better word. just started recently. im thinkin maybe the clutch is slippin but the kicker is that if i drive hard its fine. and by that i mean if i shift at 4500 in every gear she runs like a dream but if i shift at 2500 or 3000 in normal every day driving she jerks pretty hard in third...any ideas?
Old Jul 25, 2009 | 12:29 PM
when the clutch is going it will slip. are u sure its not misfireing? are u getting any trouble codes? whens the last time plugs were changed? plug wires?
Old Jul 26, 2009 | 06:17 AM
pedwards3x's Avatar
k how does slipping feel different than what i am describing? and misfire is a possibility. i get check engine light rarely but doesnt stay on but a few seconds. and last time plugs were changed was over a year ago...
Old Jul 26, 2009 | 09:12 AM
slipping clutch is like not letting the clutch out all the way so it doesnt engage all the way except the clutch is out all the way.
Old Jul 29, 2009 | 09:11 AM
Masospaghetti's Avatar
Do you get this when just accelerating, or when you engage the gear (actually moving the shift lever), or when you let the clutch out? If it does it when your just accelerating with no clutch input, its likely an engine problem, not a transmission issue.
Old Jul 30, 2009 | 10:16 AM
pedwards3x's Avatar
had it looked at yesterday...wires were gone to crap and fuel filter was plugged...so tune up should fix everything and make her run like new
cdnturboz
Aug 30, 2012 10:50 AM
camoss31
Mar 3, 2012 01:56 PM
windsorman707
82-92 V8 Tech
Oct 2, 2010 09:10 AM
Shadowed_Stranger
Dec 18, 2008 04:52 PM
JuggernautX
Apr 2, 2008 06:44 AM
