clutch/ transmission
Old Oct 2, 2010 | 09:10 AM
windsorman707's Avatar
Default clutch/ transmission
1991 z28 305 5 speed manual trans
I need help with my manual trans. with the car not running the trans shifts in all gears. with it running, you can put it in any forward gear. when you start driving, it wont shift into the next gear. also, it will only go in reverse when i turn off the engine.Otherwise it just grinds and wont go in at all. I got under the car while someone pushed in the clutch and it had the proper travel of .53 in.and doesn't loose pressure when holding it in. With the reservoir cap off, should you see any fluid movement when the clutch is depressed? because it doesn't on mine. Also, once the car is fully warmed up the car will crawl with the clutch pushed in. Any help would be great.
thanks, Mike
cdnturboz
Aug 30, 2012 10:50 AM
camoss31
Mar 3, 2012 01:56 PM
pedwards3x
Jul 30, 2009 10:16 AM
Shadowed_Stranger
Dec 18, 2008 04:52 PM
JuggernautX
Apr 2, 2008 06:44 AM
