My transmission(or clutch?) **** itself.
Old Dec 18, 2008 | 12:15 AM
Shadowed_Stranger's Avatar
Default My transmission(or clutch?) **** itself.
So my car completely **** itself as I was driving away from my house. No problems as I was leaving, until about one block away when the car just lurched and I heard alot of loud mettalic banging noises and it stopped (only going about 15). I wrestled it into gear and managed to pull forward to a parking spot. The car will not only roll if the clutch is in, and will not roll even in neutral unless the clutch is in. Even in neutral the car will turn off unless I press the clutch in.
Any suggestions? How much will a new tranny cost and where can I get one?
Old Dec 18, 2008 | 11:20 AM
95slvrZ28's Avatar
Default RE: My transmission(or clutch?) **** itself.
Well, some unfortunate news for you is that it sounds like your transmission is shot. If it were just your clutch you probably wouldn't move in any gear, but you for sure would be able to have the car in neutral without the clutch depressed. New transmissions are not cheap, but I'd check with your local junk yard and see what's local to you.
Old Dec 18, 2008 | 04:52 PM
the car will no longer move under it's own power at all, I got lucky getting it to the parking spot.
This blows. I just got a job after being unemployed for 6 months, I have no money and I don't start for another month or get paid for almost 2.
Sorry for the rant, this is just another problem in this insurmountable week of problems.
cdnturboz
Aug 30, 2012 10:50 AM
camoss31
Mar 3, 2012 01:56 PM
windsorman707
82-92 V8 Tech
Oct 2, 2010 09:10 AM
pedwards3x
Jul 30, 2009 10:16 AM
JuggernautX
Apr 2, 2008 06:44 AM
