Stock Gears
Old Sep 29, 2005 | 08:37 PM
99CamaroOwnr's Avatar
Default Stock Gears
Hey all!! I am new here and have a question. I have 1999 3.8L V6 Camaro that i love. I have a K&N CAI with Flowmaster Cat-back exhaust. I was wondering what the stock rear-end gears where and what you guys might reccommend as far as gearing for some more acceleration. Thanks
Old Sep 29, 2005 | 09:51 PM
02StanGT's Avatar
Default RE: Stock Gears
I am not quite sure, but here are some codes you can check to see if you have.
GU2 Axle, Rear 2.73 Ratio
GU3 auto tranny,
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
G80 Axle, Rear Posi-traction (Limited Slip)
Check and see if you can find any of these. Sorry I don't know where to look though. My guess would be either in the driver's side door, or under the hood. Hope this helps and let us know.
Old Sep 29, 2005 | 10:29 PM
Ok i looked on the driver side door and saw a sticker with a bunch of codes on them. I saw this code GU4. So it appears i have 3.08 in the rear? Would this be correct? What would you guys reccommend i get for some better acceleration, but want totally kill my top end or make the rpms really high at 70-80mph
Old Oct 1, 2005 | 12:57 AM
02StanGT's Avatar
I would recommend 3.73+. I had 3.27 on my Mustang and went to 3.73 and it only changed 400 rpms in 5th at 70 mph.
Old Oct 1, 2005 | 07:33 PM
Thanks alot man. I am going to go with the 3.73. I also have another question. Will i need a tuner? I work at a Car Inpection Center and one of the mechanics said i would prob need a tuner to correct my guages and some other stuff that may occure from the gear change. Also i was looking into hypertech tuners but could not find one to fit my car. I looked everywhere for one that would fit my 99 3.8L V6. I could only find year 2000 and up. Will that one work or do i need the one specifically for my year? Thanks
Old Oct 1, 2005 | 09:58 PM
02StanGT's Avatar
I'm not sure they have a tuner for your car. I saw the Hypertech one, and it said it will not work with any other years. I did some looking and found a website that sell a speedo recalibrator (Click Here...). If nothing else you can always go to a dyno tuner and have them recalibrate it for you. I think you will be very pleased with your decision. Enjoy!
heartbeat_jr
70-81 V8 Tech
17
Mar 14, 2021 05:56 PM
ginkof
Dec 19, 2012 08:39 AM
greycon88
LS Series Tech
16
Jan 19, 2012 06:28 AM
SteveO87
Apr 10, 2007 09:15 AM
fatass91
Jun 30, 2006 06:41 PM
