Speakers
Old Sep 26, 2010 | 07:37 AM
Bankos66's Avatar
Default Speakers
Ok. I have been searching for a while on the internet and here and still cant find what the speaker size is on a 99 camaro with the monsoon system. Cananybody help me? sorry that this has probably been asked 1000000 times
Old Sep 26, 2010 | 12:18 PM
evilkal's Avatar
Where at? The door speakers and rear seat are 6.5 inch. I think with the monsoon system the rear speakers are 6.5 or 8 inch subs.
Why don't you just go look at them?
Old Sep 26, 2010 | 05:59 PM
Bankos66's Avatar
i did but it looks like I can fit bigger ones and im not sure. Just trying to figure this out
Old Sep 28, 2010 | 07:13 AM
evilkal's Avatar
Why would you want larger component speakers? If you take the panels off, you will find there isn't much room nor a place to screw them in anyhow.
6.5 inch component speakers are pretty much as large as you want and need to go...
Old Sep 28, 2010 | 07:37 AM
Bankos66's Avatar
im just saying in the rear deck, it looks like it was made for a 6 x 9
Old Sep 28, 2010 | 05:26 PM
Massey's Avatar
the door speakers are actually 2 individual speakers in one package. The frame holds a 6.5 speaker and the door will hold about an 8" but I would not go that big I would keep the factory mount which also acts as a water guard. The rear seat speakers are 6.5 Subs and they are wired to the sub channel of the amp. Putting standard range speakers here will not do much (just trust me here OK) I had to rewire my amp to get full range sound to the middle speaks. OK the rear look like 6x9 but they are NOT!! those are 2 little 4" speaks that are wired to the full range channel of the amp. The way the rear pannel is designed you dont get room to mount larger speakers there. Hope this helps you.
Oh and the amp is located behind the spare tire.
Massey
Old Sep 30, 2010 | 08:42 PM
Bankos66's Avatar
That helped alot. More in depth than anything else I heard so far
Patrick Quentin Musick
Mar 17, 2013 06:50 PM
charlie94
Oct 30, 2011 12:35 AM
The Banks
Apr 12, 2008 01:36 AM
ctboy
Nov 10, 2007 08:07 AM
97camaro
Sep 11, 2005 05:48 PM
