speakers
This should help..
With Bose
http://shbox.com/1/bose_wiring.jpg
Standard Stereo
http://shbox.com/1/radio_schematic_1996.jpg
With Bose
Standard Stereo
should i have speakers in my door with the bose? im looking at the diagram n im confused
i would like to put one in each door n one on each side in the back, i guess i have bose i have the seprate speaker in the hatch on the drivers side .
should the wires that run direct to the speakers come from the factory amp or should they come from the radio?
Last edited by Patrick Quentin Musick; Mar 15, 2013 at 11:02 PM. Reason: change my question
yes and front speakers with the bose have the amp built into the speakers. its best to run new wires for aftermarket fronts.
ok im not understanding lol when i wire the new speakers should i splice behind the radio wiring harness or near the amp? a couple of days ago i pulled the amp out (i have a speaker in my pass door and one in the amp box) and the one in the door still worked this is why im confused n i would have to run wires to the drivers door and to the back sail panels because their are no wires back their
check your production codes. we need to see for sure what was in the car stock. it sounds like someone may has already been messing with it. tell us what you are wishing to do. brb
should be able to find rpo codes on a sticker in the glove box, in the center console or on the door jam. here is a link to the codes. https://camaroforums.com/forum/93-02...o-codes-50977/
document:6562 model
2g1fp22s2r2115607 1rp(8 or b)7
ah3 ak5 ar9 au0 au3 a31 a90 b84 cc1 c49 c60 c9c dg7
dl5 fe9 f41 gu5 ipb j41 k34 k68 l32 (mx0) m30 na5 np5
n96 qmt r7a r7r r8t r9z ste t96 ub3 (u1t or uit) u73 u82 vk3
v73 1az 1sc 12b (121 or 12I) 17p (6cm or 6gm) 7gm 71q (?1u) 8tc 91q
bc/cc wa-(??9913) (?21)
THE ONE IN THE CENTER CONSOLE IS GONE AND THE DOOR WAS REPLACED (RED CAR WITH A WHITE DOOR IN THE DOOR JAM) THIS WAS IN THE GLOVE BOX
Last edited by Patrick Quentin Musick; Mar 16, 2013 at 01:24 PM. Reason: cause it was editable and tasty
