canister purge valve
Old Sep 25, 2010 | 07:02 AM
typeomang's Avatar
Default canister purge valve
Still fighting the P1441 problem, I have replaced the canister purge solenoid and that did not work, replace tine canister purge valve was going to be my next step, anyone done this?
Also my problem is that the car will not turn on with the first key turn, after a couple times of the pump pressuring up it starts right up, any help would be great.......SFC
Old Sep 30, 2010 | 07:59 PM
typeomang's Avatar
no one has had this problem?
Old Sep 30, 2010 | 08:16 PM
osduck5's Avatar
Check the line between the canister and the gas tank for restrictions or leaks. Also, check to make sure you have vac at the purge solenoid and that the lines are not crossed. The canister isn't cracked or leaking is it? Check all your vac lines for leaks.
Old Oct 1, 2010 | 12:43 AM
BasicConcepts's Avatar
Technical User
have you checked fuel pressure if you put a gauge on the valve at the intake let the pump prime and check the pressure im not exactly sure what you should read but i know that if it doesnt hold odds are you have a leak either in a line or at the pump can you smell gas
sm515
Jun 4, 2013 07:53 PM
REN
Mar 4, 2012 08:09 PM
aniyishay
Jul 30, 2011 08:49 AM
97redcamaro
May 5, 2010 08:05 PM
