Spark Plugs3.4
RE: Spark Plugs3.4
I changed mine not long ago. I got the NGK V-power plugs which were pretty cheap and also Taylor Thundervolt 8.2mm wires. When I was putting the new wires on I've noticed that some of them seemed to click a little even before they were completely on. The only advice I could give you with that is to just put them in as hard as you can until you feel a really distinct click and feel that they are firmly on (if you try to pull them off they should stay locked in there, not slide off).
RE: Spark Plugs3.4
ok so i put in the NGk V-powers and my car is running good but im still gettin the poppin noise when i flow it. Coil pack? or sumthin with intake?
and does your exhaust having leaks in it( alot of leaks) cause ur car to tick?
QUICKB4C
06-15-2009 11:52 AM
