No spark
Old May 16, 2009 | 09:22 PM
draggo144's Avatar
Default No spark
I have a 91 z28 with a 305 tpi that doesn't have any spark. I rebuilt the top end and after getting everything back together and tried to start it I don't have any spark. Please don't tell me I don't have something hooked up right because I'm pretty sure that everything is. The only thing I can think of is a fuse somewhere other then the fuse block under the dash or something with the distributor. I got a new coil and tested the ignition control module which passed so I don't know anymore. Any help will be appreciated.
Old May 20, 2009 | 12:43 PM
sammycamrestorer's Avatar
Cool no spark?
what exactly did you rebuilt on the top end and what did you remove and replace? I might be able to help you. Theres about 10 different things that could be wrong and easily fixed?
Old May 24, 2009 | 11:23 PM
draggo144's Avatar
Well I did a full top end rebuild. I had rocker arm studs raise out of the head so I had to pull the heads. Just the block was left in the compartment.
Old May 25, 2009 | 03:54 AM
got juice to the coil and the dist. get the test lite and or the ohm/volt meter and see what u can find out.
sebi1990
Oct 10, 2010 10:24 PM
91camaroRSZ
82-92 V8 Tech
Sep 10, 2010 04:43 AM
87irocguy
Dec 1, 2008 04:11 PM
ChampionN84
Oct 1, 2007 10:59 AM
