86 iroc elect. fan not working with a/c on
Old May 25, 2009 | 01:44 PM
gaskincrew's Avatar
Default 86 iroc elect. fan not working with a/c on
my head pressure on low and high is going out of sight, what activates the fan relay when pressure gets to high?? my fan is coming on when temp get up so relay is good ,just not coming on when head pressure up with a/c on
Old May 25, 2009 | 06:08 PM
blackz87's Avatar
If you have the two fan system GM made the Passenger side fan come on at 220 Deg with the A/C on, otherwise it does not run. I feel 220 is too hot for me trafic and it is only 180 deg on highway. But that is my opinion and not too much you can do, except install a manual fan switch which I don't like. Anytime you start hacking it only screws things up more.
Old May 25, 2009 | 09:08 PM
gaskincrew's Avatar
there is only 1 fan ,, my head pressure is over 300 on high side and i turn the a/c off because stuff starts making noises, it should activate something to turn on cooling fan to lower a/c head pressure""" somebody correct me if im wrong,
YO-EL
Mar 17, 2012 07:19 AM
vzfox
Jun 10, 2007 07:26 PM
sewerrat
82-92 V8 Tech
Jan 14, 2007 09:33 PM
