Service vehicle soon light
Old Aug 17, 2011 | 01:04 PM
4bangerhater94's Avatar
If its just and oil change reminder then to get rid of it you should just be able on a GM
OBD II is just turn the key to the battery on position hit the gas pedal three times and put your foot on the brake that should get rid of it.
Whats your mileage? Could just be one of those annoying mileage recommendation lights.
Old Aug 17, 2011 | 07:23 PM
Schappie9's Avatar
Thank you... u have all been very helpful.
Old Aug 17, 2011 | 08:26 PM
Originally Posted by Schappie9
This is coming on when temp gets around 210-215. Usually BRAKE light is illuminated also.
These two things could be related. Check the brake fluid level in your reservoir. A "Brake" light on in the dash, if it's not an electrical issue from the e-brake, means you could be low on fluid, or have air in the system. If that's the case, that could also be what's tripping your maintenance light.
Old Aug 17, 2011 | 11:24 PM
Schappie9's Avatar
Ok.. say I'm sitting in traffic ( I have mechanical gauage and the electronic guage) and its a hot day. The temp increases to aprox 228 when the fans come on.. I know.gauges r right cuz I have checked temp VIA scan tool, the lights will both come on... the SVS and brake light.. I have a feeling it may have something to.do.with the water temp. Unless the heat in the car is effecting the brake sensors..Idk.. But this has nothing to do with lol change..
Old Aug 18, 2011 | 12:13 AM
Do both lights turn on at the same time, and like clockwork when the fans switch on?
Old Aug 18, 2011 | 12:53 AM
Schappie9's Avatar
Ya, they both come on at same time. I can't hear of fans come on, but its right at that temp.. bout 228 degrees.
Old Aug 18, 2011 | 01:52 AM
Just for fun, have you checked your brake fluid level yet? Also try unplugging the wire from the pressure switch at the master cylinder. That switch will turn on your dash brake light if it reads low pressure, or air in the system. Curious if the warning lights will still go on the same way then.
vanvo
May 8, 2011 05:37 PM
Chappie99
Aug 3, 2008 08:42 PM
