service engine soon light???
Old Aug 27, 2010 | 12:55 PM
mac022705's Avatar
Default service engine soon light???
i have a 97 rs that starts just fine until the service engine soon light comes on, then won't start, will turn over and is getting fuel at the injectors but no fire. i had the codes read and the only thing was an egr error. i clear the light and she starts right up. starting to happen alot more frequently. any thoughts??
Old Aug 27, 2010 | 02:35 PM
First thought is it a PCM failure. The code is not stored because its not one of the things the engineers planned on failing.
I am not saying that what it is just my first thought. You need to back track the no spark and see if it leads you to the PCM. Could be a cranks sensor or ton of othe things.
Old Aug 27, 2010 | 02:46 PM
libertyforall1776's Avatar
Which is the specific code #(s) you have?
Rent
Apr 22, 2013 11:08 PM
bchbmjohn9
Sep 5, 2010 11:44 PM
93CamaroGirl
Apr 27, 2007 01:15 AM
red99camaro
Apr 12, 2007 12:04 AM
eric302
Aug 19, 2005 10:58 PM
