Project Sleeper
#31
Woot! Crank is going to be done this week! tomorrow I start ordering more parts to assemble the short block.
Also thought I would finally reveal my goals. Turbo, 12's in the 1/4. That is all.
#35
lol, I love throwing people for a loop. Guess I should mention that it MIGHT be supercharged, depends on if a sponsor on FTV6 comes through with the procharger design. With that, I can make some serious power still, without exhaust running all over the place. We'll see though.
#36
Got some parts in, still waiting on the $%&*!@# crank, that company is so slow, not going back to them again. Soon as they're done, I can order a lot more parts. Found a brand new pre-bad batch JP double roller chain for cheap, so that is on the way at least.
![Name: 100_2270.jpg
Size: 77.6 KB](https://camaroforums.com/forum/attachments/93-02-v6-tech-14/39605d1501331574-project-sleeper-100_2270.jpg)
#40
just ordered:
arp head studs
arp rod bolts
arp flywheel bolts
cam bolt
main bearings (10 over)
rod bearings (10 over)
cam bearings
complete gasket set
rings
brass freeze plugs for the block
Then the entire rotating assembly will be balanced when all this shows up. PROGRESS!
arp head studs
arp rod bolts
arp flywheel bolts
cam bolt
cam bearings
complete gasket set
rings
