problem with power window and signal lights
Old Feb 7, 2010 | 11:27 PM
tangentspace's Avatar
Default problem with power window and signal lights
power window: the up button sometimes doesn't work.
signal lights: some times work, some times don't work
any solution?
thanks!
Old Feb 8, 2010 | 12:14 AM
raysean22589's Avatar
maybe some loose connections on the back of the butons for the windows
Old Feb 8, 2010 | 12:38 AM
1987IROCZ's Avatar
pull the switch out and make sure the connector is tightly plugged in...as for the turn sigs.....um turn sig switch mite b goin bad on u
Old Feb 8, 2010 | 11:40 AM
what yr and model car?
Old Feb 8, 2010 | 11:48 PM
It's 1997 Camaro RS V6
Old Feb 9, 2010 | 12:00 AM
does the window go slow and then stop. then a few minutes later it will work? when the lights quit working, do both sides quit or just one side? do they not come on at all or do they come on and not blink?
Old Feb 9, 2010 | 11:34 PM
Hi craby: you must know this problem really well! Yes, the window goes slowly up then stop, then a few minutes later it works again. As for the lights, just one side at a time. I don't know if they come on or not, I'll have to get out of the car to look next time when it misbehaves.
Old Feb 10, 2010 | 12:08 AM
the window motor is going on that side. there is a sticky on here for it or use this.
http://shbox.com/page/windowmotor.html
so the blinker/turn signal is not blinking but the light in the dash comes on and if u switch to the other side blinker it will blink. that would indicate a light is out on that side. if neither light will blink when it acts up i would look to the flasher for the blinkers.
Tar Heel
Aug 21, 2009 03:55 PM
ForgetfulRegrets
Jan 15, 2007 11:30 PM
Rise65
Nov 6, 2006 11:09 PM
Shifty
Feb 19, 2006 04:20 PM
