Plastic Elbows on Belt Tensioner/WaterPump
I replaced these less than 6 months ago using the ones AutoZone sold in the HELP package. Now they are leaking again. Are the GM OEM parts any better? I lubricated the o rings with motor oil before putting them in. Should I have done differently?
I can go by another Help set for less than 5 dollars but if it will permanently put this issue to rest I will pay $25 to get oem. Any opinions?
I assume you mean RTV like the permatex orange. Would you just use that and the less than $5 aftermarket elbows or would you go with OEM. And if you use the RTV do you let the car sit overnight before running water back threw.
I found that the OEM ones are no better than the HELP ones. GM has a TB out on the 3800 regarding the elbows leaking and the TB recommends using a sealant on them. I used Bearing grease and mine have stayed sealed.
Massey
Massey
