Belt tensioner
Old Jan 15, 2011 | 01:10 PM
quace's Avatar
Default Belt tensioner
I have a fourth generation Z28. My belt squeaks in damp conditions and I can tell a slight lose in power when i get on it. I was told that it was the belt tensioner, I had it changed and everything was okay for a couple months but the problem is happening again. I know that there is a lot of pressure on the belt and was just wondering if this was common to have the tensioner go bad often or if there was something else that was wrong.
Old Jan 15, 2011 | 01:37 PM
Massey's Avatar
did you replace the belt too? and what 4th gen do you have the LT1 or LS1? The LS1 has 2 tensioners you may have replaced the wrong one. Also idler pulleys can also tweet when damp.
Massey
Old Jan 15, 2011 | 02:07 PM
MyShibbyZ28's Avatar
If the squeak was not properly identified as coming from the tensioner than you may have replaced it without need/cause. My car also squeaks when wet or damp and simply giving the belt a quick squirt of WD40 stops the squeaking. I have only heard of tensioners going bad when something else also failed, such as the belt coming off or excessive force on the belt.
Old Jan 15, 2011 | 02:12 PM
quace's Avatar
I have a LS1. I'm not sure one the detail of what was changed. I had someone else do it for me.
Old Jan 15, 2011 | 02:13 PM
quace's Avatar
Ok Thank you Shibby
Old Jan 15, 2011 | 02:44 PM
Massey's Avatar
You may want to find out what was replaced. You have one tensioner and idler per belt and 2 belts. It could also simply be a warn belt. DO NOT spray anything directly on the belt it will shorten its life and posably cause damage to other items from slipping.
Massey
P.S. Belt conditioner is marketed for all belts but only good for V-blets.
Old Jan 15, 2011 | 02:54 PM
put a new gator belt on mine and the squealing stopped.
Old Jan 15, 2011 | 03:19 PM
Massey's Avatar
Goodyear Gator or Gates premium are the best ways to go with these cars.
Massey
Old Jan 15, 2011 | 06:40 PM
auto's Avatar
+1 on the goodyears
Old Jan 16, 2011 | 10:49 PM
quace's Avatar
Thank you for the info i wil try a gator belt, I have a lose of power when i shear down on it at about 2500 rpms in every gear it is very sudden but it is noticeable could this be cause by the belt or do yall have any suggestions on what it could be?
