oil & tranny
Old Nov 10, 2006 | 10:58 PM
sooperdewd's Avatar
Default oil & tranny
So Im going to flush the tranny and change the oil, car is garage kept hanst been driven or changed since july of last year so I was wondering the best oil for it and tranny fluid, its the 3800 v6 3.8l.
Old Nov 11, 2006 | 01:01 AM
Default RE: oil & tranny
If the tranny is stock, you can't go wrong by using DEXTRON III. If it is modified, you will have to experiment.
Old Nov 11, 2006 | 01:24 AM
shnormo's Avatar
Well a lot of fluids meet dexron III requirements. I personally like Royal Pruple's ATF or TCI blue racing fluid. I recomend Royal Purple for High HP motors!
Old Nov 11, 2006 | 01:43 AM
JaySan's Avatar
I have heard that Royal purple oil SUPPOSEDLY increases HP in the LS1 engine is, it true for the 3.8 liter series II engine ?
Old Nov 11, 2006 | 12:39 PM
SLJ2137694's Avatar
DEXRON VI has just been released by GM and it is a much improved auto trans fluid. It can be used anywhere DEXRON III was used.
ORIGINAL: z28pete
Old Nov 26, 2006 | 01:42 PM
libertyforall1776's Avatar
Default Dexron VI was:RE: oil & tranny
Cool, thanks for the tip.
Some details are here:
Dexron VI
Old Nov 26, 2006 | 08:34 PM
shnormo's Avatar
Default RE: Dexron VI was:RE: oil & tranny
Dexron VI is a little expensive right now.
Old Nov 28, 2006 | 02:26 AM
Maybe so, but seems more than worth it... Strangely a local GM shop I am using did not even have Dexron-VI, and had to special order -- bulk ATF was still Dexron III... They seemed to be largely unaware of it, despite being out for 1 yr+ Same is true for Murray's -- they hadn't heard of it, and cannot special order it -- yet.
Automatic Transmission Fluid — DEXRON® VI
The most recent release of the DEXRON series of automotive transmission fluids. It features the same low temperature performance characteristics as DEXRON IIE.
Size:
1 qt.
1 gal.
55 gal.
Item #:
88861003
88861045
88861046
Summary:
Petro-Canada ATF Dexron-VI Approved from General Motors
The First Approval from General Motors for all 2006 & beyond (Check out Downloads)
Applications:
Petro-Canada Dexron®-VI ATF is recommended for all 2006 and beyond GM vehicles with Hydramatic automatic transmissions. It is fully back serviceable for Dexron®-III (H), III and IIE applications. Meets GM specification, GMN10060. Always consult your vehicle owner's manual for specific recommendations.
Petro-Canada was granted the first DEXRON®-VI ATF license number from General Motors (J-60001).
FEATURES & BENEFITS:
Extended fluid life
Extends life of transmission
Potential to extend drain intervals
Enhanced Product Performance for newere and older transmissions
Outstanding resistance against sludge & deposit formation
Improved oxidation and thermal stability versus Dexron®-III (H) ATF
Superior anti-wear protection
Outstanding low temperature fluidity
Enhanced foam control which maintains responsive shifts and reduces wear on bearings, bushings, and gears
Improved Fuel Economy versus DEXRON®-III (H) ATF
Improved torque transfer versus DEXRON®-III (H) ATF
More consistent viscosity profile which maintains a consistent torque performance
Lower viscosity versus DEXRON®-III (H)
Improved shear stability
This unique fluid is specially formulated to provide twice the service life of a DEXRON®-III (H) ATF and offers enhanced performance for both new and older transmissions.
Straight from GM:
General Motors DEXRON®-VI Global Service-Fill Specification
More details from the 1st Dexron-VI licensee:
Petro-Canada TechData DEXRON®-VI ATF Automatic Transmission Fluid
WIspartan1026
Mar 25, 2010 09:58 PM
bhoeksema
Mar 6, 2010 08:38 PM
blowncamaro
Oct 12, 2009 09:05 PM
rancheronut
Jul 14, 2009 01:12 AM
mpd228
May 11, 2009 09:52 PM
