Oil manual transmission,power steering and differential
Old Feb 7, 2011 | 03:41 AM
flescenberg's Avatar
Default Oil manual transmission,power steering and differential
Hello everyone, I bought a 3.8 v6 2000 camaro in Italy manual transmission. I have a hard time finding information on the types of oil to use in manual transmission, power steering and differential.
Can you tell which oils are recommended for my car?
Sorry for the poor quality of my English!!
Thanks to all
Old Feb 7, 2011 | 07:57 AM
mrfreez's Avatar
Manual Transmission: Dexron III
Differential: SAE 75W-90 Synthetic
If you have a limited slip differential, you need to add the limited slip additive lubricant
Oil: 5W-30 (I use 10W-30 in the summer and when it is hot)
Power Steering Fluid: GM power steering fluid P/N 1050017 If you are in a cold climate you need to use GM fluid 12345866
Old Feb 21, 2011 | 01:39 AM
Exclamation AIR Conditioning
Thank you very much, for even if you know which is the amount of gas of the air conditioning?
greetings
George7659
Aug 16, 2012 07:38 AM
v64thgen
Feb 18, 2012 08:34 AM
the weiand one
Jan 17, 2012 01:44 PM
JJDemy
70-81 V8 Tech
Oct 19, 2009 09:06 AM
camarohead
Apr 29, 2009 10:13 AM
