Oil leak
Old Dec 11, 2011 | 07:13 PM
RFxCamaro's Avatar
Default Oil leak
So i got a oil leak on my coming from my oil pan i believe. It seems like its leaking from the bolt. Have any of you replaced the oil pan on a 96 3.8? any tips?
Old Dec 11, 2011 | 08:08 PM
iLL95's Avatar
I Like to Party
Super Member
You may need to jack the engine up a bit to make enough clearance to take out the oil pan, I would also replace the gasket/seal as well. Idk if a 96 requires tinkering with the tranny at all, I'm sure someone here can point it out
Old Dec 11, 2011 | 08:17 PM
3800camaro's Avatar
Oil pan sounds fine. Just needs a new gasket. I'm not sure how to remove the oil pan tho. Shouldn't be to hard. Just jack it up drain oil and unbolt.
Old Dec 11, 2011 | 08:52 PM
RFxCamaro's Avatar
Yea but the crossmember is in the way. O nd yea I meant Gasket sorry.
Old Dec 11, 2011 | 10:38 PM
3800camaro's Avatar
Should be able to unbolt everything tilt the rear of it down far enough to slide the new gasket under the oil pump and rebolt everything back up.
Old Dec 11, 2011 | 10:42 PM
iLL95's Avatar
I Like to Party
Super Member
While your down there, if there is any, I would clean any residual oil deposits that may have caked around the gasket seals
Old Dec 11, 2011 | 11:19 PM
RFxCamaro's Avatar
I already cleaned some up to find the leak. I have pacesetters so I'm also going to have to remove the y pipe. It's gon be fun.
Old Dec 14, 2011 | 02:34 PM
vanquishfist's Avatar
The manual says you need to drop the cross-member.
Are you sure it's not the rear main seal? That can be mistaken for a leaky pan gasket.
Jelz28
Jul 18, 2012 06:01 PM
95mero
Jan 5, 2009 09:14 AM
derrickdiggler
Oct 12, 2007 01:22 AM
derrickdiggler
Sep 27, 2007 02:26 PM
daltons 1980
Sep 24, 2007 09:04 AM
