Fuel Injector Problem...
Old Dec 14, 2011 | 10:38 PM
SalsCamaro2000's Avatar
Default Fuel Injector Problem...
I have a 2000 V6 3800 series camaro and my service engine light was on and i went to go get it scanned and what came up is cylinder 5 failure i got that fixed and a fuel injector failure also came up, when i step on the gas my car hesitates to go, when it idles the exhaust putters/pulses. And when i accelerate i get a very heavy exhaust/gasoline smell coming from my A/C. any idea on what fuel injector it could be, or any possible smaller problems??
Old Dec 15, 2011 | 12:25 AM
BasicConcepts's Avatar
Technical User
What was the code for the injector??? What was done about the cyl 5 misfire???
Old Dec 15, 2011 | 12:54 AM
iLL95's Avatar
I Like to Party
Super Member
A fuel injector problem could definitely lead to a de-pressurized fuel system, which in turn could lead to the sputtering. It could also be a pump error as well. How did you fix the 5th cylinder? Was it a misfire? Your A/C system is directly correlated with your vacuum system. If you have a vacuum leak in turn with an exhaust leak, it could lead to exhaust fumes(carbon monoxide) inside the cabin. It isn't something that should be taken lightly as it can cause light headedness and nausea. I would replace the injector and use seafoam in the brake booster line to pinpoint any existing leaks
Kendagenius
Feb 5, 2017 12:23 PM
jcase350
82-92 V8 Tech
Mar 15, 2012 08:06 PM
snake10556
Jun 14, 2007 02:37 AM
johnson3034
May 25, 2007 09:35 PM
