no spark
Old Mar 16, 2010 | 09:15 PM
camaro1380's Avatar
Default no spark
i have a 98 camaro 3800 series 2 i was driving it to work and the car died while driving. I had the ICM tested and it is good. i have no codes that would give me no spark and i dont believe that all 3 coil packs just went all at once. I need some help here
Old Mar 16, 2010 | 09:31 PM
osduck5's Avatar
Start by checking fuses.
Old Mar 17, 2010 | 06:58 AM
camaro1380's Avatar
all fuses are good as well as the relays
Old Mar 17, 2010 | 06:59 AM
camaro1380's Avatar
i have been thinking Cam and/or crank sensor
Old Mar 17, 2010 | 07:23 AM
osduck5's Avatar
According to the flow charts for testing "no spark", it points to either the ICM or crank sensor, if you know everything else is good.
Old Mar 17, 2010 | 08:02 AM
camaro1380's Avatar
well i had the ICM tested yesterday and it is good so i am going to try the crank sensor. is there a way to test the crank sensor also will that set a DTC code if so what?
Old Mar 17, 2010 | 08:11 AM
camaro1380's Avatar
anyone have an ignition wiring diagram?
Old Mar 17, 2010 | 04:24 PM
camaro1380's Avatar
ok so i have isolated the issue there is a pink wire that runs into the fuse block under the hood with a 15a fuse labeled eng control i jump the wire and the car starts but i am getting no power if i dont jump it. the haynes manual i have is not giving me specfics on the wire casue there are several pink wires anyone have a better diagram of this ip fuse block?
Old Mar 17, 2010 | 06:25 PM
osduck5's Avatar
Is the 15a fuse blown? Not sure about posting wiring diag due to copy write issues these days.
sebi1990
Oct 10, 2010 10:24 PM
draggo144
82-92 V8 Tech
May 25, 2009 03:54 AM
87irocguy
Dec 1, 2008 04:11 PM
ChampionN84
Oct 1, 2007 10:59 AM
